e1
0617 (9)
EC Type-Approval Certificate
*502373*
Approval No.:
Issued by:
Place & date of type-approval:
Report No.:
Issued by:
Date of issue:
Approval identification:
e1*97/24*2013/60/9/III*0617*04
Kraftfahrt-Bundesamt, Office building, Fördestraße 16, DE-24944 Flensburg, Germany
DE-24932 Flensburg, 08.04.2015
06-00114-CM-GBM-04
TÜV SÜD Auto Service GmbH Westendstrasse 199 DE-80686 MÜNCHEN
05.03.2015
e1 0617 (9)
Type and version of exhaust: M-HZ005 / M-HZ00501C, M-HZ00501T, M-HZ00502C, M-HZ00502T, M-HZ00503C, M-HZ00503T, M-HZ00505C, M-HZ00505T, M-HZ00506C, M-HZ00506T
Marking: Engraved by laser / plate fixed with rivets Field of application:
Manufacturer
Commercial description
Vehicle type and no. of homologation (starting with no. of homologation)
Engine type
Component parts, dimensions in mm
Dimensions of the part in mm or original part / replacement part
Akrapovic
part no. Or homologation no.
Suzuki (J)
GSX-R750
WVCF (e4*0890*)
R743
Header pipes Original parts -
R744
Collector Original parts -
GSX-R600
WVCE (e4*0849*)
N732
Link pipe - 105977
N733
Link pipe with Catalytic converter - P-KAT-026 ; e1*0759*(5)
N734
Rear silencer Hexagonal 103 x 130 M-HZ005 ; e1*0617*(9) (Outlet pipe ø 38 mm Length without end caps 350
Inlet pipe ø 60 mm)
Piaggio & C.S.p.A. / Aprilia
RSV 4 Factory / R
RK (e11*0749*)
V4 - A / V4
V4 - E
Tuono V4 R / Factory
TY (e11*1156*)
V4
V4-G
EC Type-Approval Certificate for non-original motorcycle exhaust system
www.akrapovic.com
Das ist bei Jam Parts eine PDF Datei ich habe sie nur so kopiert der Topf ist mit dem Kat
e1 0759 TÜV zugelassen so wie es auch schon Toni 75 geschrieben hat.
