ECU IST VERKAUFT!!!!!!!
Biete eine Aprilia Racing Kit ECU Marelli COE13021 (nicht zu verwechseln mit der Standard Racing ECU) für die RSV4 an.
Habe die ECU in meiner RSV4 Factory APRC 2011 gefahren.
Folgende Features hat die ECU:
- Optimized Traction control Management (TCS):
Less invasive in every selected level.
Optimized behavior especially at high lean angles and quick direction changes.
Optimized Anti Wheelie torque management at level 1.
Optimized Launch Control System at level 1.
Reduced Engine braking, especially in lower gears.
- New Rev. Limiter:
13000 RPM in 1,2,3 and 4 gear.
13300 RPM in 5 and 6 gear.
- Full power Engine maps, optimized for racing exhausts.
- Possibility to choose among three maps:
T – direct Throttle response, recommended for expert riders.
S – T map with a softer response at lower throttle position. Recommended for NON-expert riders or for low grip conditions.
R – T map with an even more reduced engine braking.
- Without immobilizer.
Can also be used on RSV4 Factory, with ABS.
siehe auch: http://www.serviceaprilia.com/publi...accessories/01_Kit_ECU_Marelli_AR&Contafile=1
Neupreis inkl. Lieferung aus Italien ca. 600,- Euro.
Preis: 300,- Euro inkl. Versand bei Vorüberweisung.
