Verkaufe die Marelli Kit ECU by Aprilia Racing - COE13021 für die RSV4 APRC Modelle bis 2014.
ECU configuration: RF1301-11
Zusätzlich verkaufe ich den BMC Race Luftfilter mit Rahmen .
Die Partnr. ist 563/08
Zusammen 595 € oder Verkauf auch einzeln möglich.
ECU configuration: RF1301-xx (RSV4 factory aprc)
FEATURES:
Optimized Traction control Management (TCS):
o Less invasive in every selected level.
o Optimized behavior especially at high lean angles and quick direction changes.
Optimized Anti Wheelie torque management at level 1.
Optimized Launch Control System at level 1.
Reduced Engine braking, especially in lower gears.
New Rev. Limiter:
o 13000 RPM in 1,2,3 and 4 gear.
o 13300 RPM in 5 and 6 gear.
Full power Engine maps, optimized for racing exhausts.
Possibility to choose among three maps:
T – direct Throttle response, recommended for expert riders.
S – T map with a softer response at lower throttle position. Recommended for NON-expert riders
or for low grip conditions.
R – T map with an even more reduced engine braking.
Without immobilizer.
Can also be used on RSV4 Factory, with ABS.
IMPORTANT NOTES:
· This ECU can be used ONLY for racing activities on circuits, and in every case NOT for standard use in public
roads.
· This ECU has to be set to the bike using the official dealer’s P.A.D.S.. It is interchangeable with the standard
Marelli ECU.
· This ECU has no guarantee. Aprilia Racing decline any kind of responsibility for problems or damages caused from
its use.
· Please, Remind always that unsafe electronic parameters can cause damages to the bike and its riders.
FEATURES:
New Rev. Limiter:
IMPORTANT NOTES:
roads.
Marelli ECU.
its use.
