Verkaufe RSV4 Racing ECU Noale
LAZMONSTA
Hallo Ihr Lieben,
Hier was ganz feines, direkt von Aprilia Racing, eine Kit-Racing ECU mit optimierten Einspritzkennfeldern und Auf Slicks angepasster Wheelie und Traktionskontrolle und verbesserter Motorbremse. Daneben noch mit erhöhter Drehzahl im 5. und 6. Gang.
RF1301-43
HW100
only for Race-Use.
VB 625euro.
Beste Grüße
Lazmonsta
Hallo Ihr Lieben, aufgrund der vielen Nachfragen, nachfolgend eine detaillierte Mappingbeschreibung der Kit-ECU:
Kit Marelli ECU by Aprilia Racing - COE13021
ECU configuration: RF1301-xx (RSV4 factory aprc)
FEATURES:
Optimized Traction control Management (TCS):
- Less invasive in every selected level.
- Optimized behavior especially at high lean angles and quick direction changes.
- Optimized Anti Wheelie torque management at level 1.
- Optimized Launch Control System at level 1.
- Reduced Engine braking, especially in lower gears.
- New Rev. Limiter:
o 13000RPM in 1,2,3 and 4 gear.
o 13300RPM in 5 and 6 gear.
- Full power Engine maps, optimized for racing exhausts.
Possibility to choose among three maps:
T– direct Throttle response, recommended for expert riders.
S– T map with a softer response at lower throttleposition. Recommended for NON-expert riders
or for low grip conditions.
R– T map with an even more reduced engine braking.
Without immobilizer.
Can also be used on RSV4 Factory, with ABS.
IMPORTANT NOTES:
• This ECU can be used ONLY for racing activities on circuits, and in every case NOT for standard use in public
roads.
• This ECU has to be set to the bike using the official dealer’s P.A.D.S.. It is interchangeable with the standard
Marelli ECU.
• This ECU has no guarantee. Aprilia Racing decline any kind of responsibility for problems or damages caused from
its use.
• Please, Remind always that unsafe electronic parameters can cause damages to the bike and its riders.
